Where's the terminal window?
Pongo
#1
In Linux do I have to do something different to get the terminal window to open in AXEpad?
Pongo
#3
I misread your question.
Can you see ttyUSB0 in /dev?
I'm using a real serial port, not USB. Programming functions are working fine so there's no problem between the editor itself and the port /dev/ttyS0. It's on Mint 18 Cinnamon.
Test prog:
' PICAXE-20X2
#picaxe 20x2
#Terminal 1200
#No_Table
#No_Data
Symbol LED = A.0
Again:
SerTxd ("Hello World!")
SerTxD (CR, LF)
High LED
Pause 100
Low LED
Pause 100
Goto Again
#4
Get rid of the "#Terminal 1200" line. It only works with the PE.
If that doesn't work try replacing it with: "#com /dev/ttys0" and see what happens.
The only thing that stops me getting the terminal window is when I don't have the download cable connected. You could have a look at /home/username/.LinAXEpad/axepad.ini to check the [Linux Target].
Try going to the folder containing LinAXEpad then right-click/"Open a terminal here". Type ./LinAXEpad then try to open the terminal window. You might get some usefull error messages.
You could put a "debug" command in your program to see if you get the debug window.
Pongo
#5
Thanks for all your suggestions.
There's no problem with Debug.
I'm going back to windows/PE6 to get my project done, and I'll get back to testing this again later.
