VSM Component Error SAA1064
Jaden
I am using an SAA1064 in my project. The VSM software says that pin 23 is SCL and 24 in SDA. As per the SAA1064 Data Sheet pin 24 is SCL and 23 is SDA. As I am yet to get it to work properly (newby @ i2c). Can anyone tell me if how to change the component lable of the SAA1064? It is not an issue now as I can swap the two i2c lines over when I work out what I have done wrong but this could be an error with whoever put that IC in??
Thanks
Right click over the component and 'decompose' it. Draw a selection box around the decomposed area, right click and make a new component. You can then rearrange pins as required as you step through the component wizard.
