Hi all
This is a bit of a general electronics post so i dont know if i am allowed to post it here but if not sorry.
I know what ohms law is and i know how to work out the resistance for an led. But I do not understant what is more important voltage or current.
I was told once if the voltage is right then the load will only draw the current it needs. When i connected my luxeon led to 3.6v by way of 3 nimh cells insteadof drawing is rated 350ma it drew 1.2a and died DOH!!! I though because the voltage was right i did not need a resistor.
Now i the final project i will be using a power supply that flutuates from 10.5v to 8.5v so to run one luxeon i need to regulate it the question is if i use a lm317 and a series resistor i can limit the current to 350ma but i think the voltage will still be 10.5 to 8.5v will this kill the led. does voltage matter if the current is limited ro should i limit the voltage and forget the current. Or have i got compleatly the wrond end of the stick.
Well im confused and now my head hurts![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Any help much appreciated
Thanks
Joe.
Thanks
Joe.
