Hello all,
I've been working the 8 and 14m chips for a few months now and have been really impressed. I've been using these chips to interface to my RC tank.
I'll be the first to admit that I'm no electronic whiz but dabble with it just enough to get my into trouble.
I decided to take the plunge and ordered the Vmusic2 and a 28x1 Picaxe.
I want to use these for a motor sound effects. Pretty simple idea, use the picaxe to take signals from the transmitter (easy enough), tell the Vmusic to play one of three 10 second clips. Motor at idle, motor rev's up and motor at high speed. I need the sound tracks to be able to move from one sound clip to another as the transmitter stick is moved. So far I can get the unit to play a clip, a few seconds or even the whole thing.
After a few days of working with the V module I have managed to make a little head way. But found myself asking more questions than I can seem to find answers or information for.
I do not have the patch cord but instead have been using the Hyper-Terminal program that comes up during running the picaxe. I have managed to found out that my V-module used software version 1.12. I have been able to upgrade this the latest of 3.XX. I been using serial commands. Mostly using the code snipplets found on this site.
Okay, now a for a few general questions for those of you have worked with this unit. Am I the only one that can't seem to get the volume command to work? Okay not a big deal for me on this project as I plan on routing the sound through a amp and speaker. But for some reason this little bit is driving me nuts.
When the Terminal Box is running during program execution, no matter what I type in to the Output Buffer box nothing seems to matter. For instance I can issue the stop command when a track is playing , hserout 0,("vst",CR) and nothing happens. Am I'm wrong thinking I can use to issue direct commands to the Vmusic?
One of the things I noticed but doubt I can do anything about is the delay time between playing of tracks. It seems to be a second or so but is quite noticeable. Anyway to make the gap any shorter?
Finally, before I wear out my welcome. I noted in the few programs I have found for this player, that each time a command such as play or stop the next thing in line is a get_response: routine. Could you please explain that bit a little for us less knowledgeable about such.
I do have more questions but will wait before I bother you good folks anymore.
Thanks,
Rusty Bates
Thanks,
Rusty Bates
