#picaxe 14m2
#terminal 4800
Symbol TX = B.4
Symbol RX = C.3
Symbol BUSY_PIN = pinC.2
Symbol BAUD_FREQ = M8
Symbol BAUD = T9600_8
Symbol cmd = b0
Symbol arg = w1 ; b3:b2
Symbol arg.lsb = b2
Symbol arg.msb = b3
Symbol varA = w2
symbol varB = w3
Symbol BTN = PinB.5 'volume up
Symbol BTN1 = PinB.3 'volume down
Symbol BTN2 = PinB.2 'next song
Symbol AXE134pin = C.1 'connected to screen input
Symbol Pressed = 1
init:
High TX ; set TX pin high for idle high serial
SerTxd("Get ready to Rock", CR, LF )
Pause 2000
'varB = 8 'initial volume setting
'cmd = 0x06 : arg = varB : Gosub Send
'SerTxd("init volume set to ", #varB, CR, LF ) ' added to display its value at this time
'pause 2000 ' added pause to see if it helped
read 0,WORD varB 'added to read previous volume from eeprom position 0
'SerTxd("eeprom volume set to ", #varB, CR, LF )
SEROUT AXE134pin , N2400_4 , ( 254 , 128 ); Position the cursor (at start of top line)128 top line
SEROUT AXE134pin , N2400_4 , ( "Programming by Rampz") ; Send to AXE134
SerTxd("Selected USB", CR, LF )
cmd = $09 : arg = $0001 : Gosub Send '0001 for usb, 0002 for sd card
pause 4000
cmd = 0x07 : arg = 0002 : Gosub Send ' EQ rock
SerTxd("Equlizer set to rock", CR, LF )
SEROUT AXE134pin , N2400_4 , ( 254 , 192 ); Position the cursor (at start of top line)128 top line
SEROUT AXE134pin , N2400_4 , ( "Equ to Rock, Set USB") ; Send to AXE134
cmd = 0x06 : arg = varB : Gosub Send 'Volume set at 8 of 30, altered to read varB
SerTxd("volume set to ", #varB, CR, LF ) 'display volume setting from eeprom hopefully
SEROUT AXE134pin , N2400_4 , ( 254 , 154 ); Position the cursor (at start of top line)128 top line
SEROUT AXE134pin , N2400_4 , ( "Volume=" , #VarB ," " ) ; Send to AXE134
Pause 1000
Gosub playsong
playsong:
For varA = 1 To 114
SerTxd("Playing song 000", #varA, CR, LF )
SEROUT AXE134pin , N2400_4 , ( 254 , 215 ); Position the cursor (at start of top line)128 top line
SEROUT AXE134pin , N2400_4 , ( "Playing Song " , #VarA ," " ) ; Send to AXE134
cmd = $12 : arg = varA : Gosub Send
Pause 1000
Do While BUSY_PIN = 0
Pause 100
IF BTN = Pressed then
pause 200 Gosub volumeup
IF BTN1 = Pressed then
pause 200 Gosub volumedown
IF BTN2 = Pressed then
pause 200 Gosub playnext
next
Pause 1000
Send:
SetFreq BAUD_FREQ
Pause 10
SerOut TX, BAUD, ( $7E, $FF, $06, cmd, $00, arg.msb, arg.lsb, $EF )
SetFreq MDEFAULT
volumeup:
varB = VarB + 1 max 30
write 0,WORD varB 'write value to eeprom positiom 0
SEROUT AXE134pin , N2400_4 , ( 254 , 154 ) ; Position the cursor (at start of top line)128 top line
SerTxd("volume ", #varB, CR, LF )
cmd = $04 : arg = $0000 : Gosub Send
Volumedown:
varB = VarB min 1 - 1
write 0,WORD varB 'write value to eeprom position 0
cmd = $05 : arg = $0000 : Gosub Send
playnext:
varA = varA + 1
cmd = $01 : arg = $0000 : Gosub Send
'cmd = 0x08 : arg = 0001 : Gosub Send 'repeatably play song 0001
'cmd = $12 : arg = 0001 : Gosub Send 'play song 0001
