I'm working on a project using the VMusic2, and a PICAXE-28X1 is (currently) acting as a crude converter between serial and the Texas Instruments linking protocols. I'm using the hardware serial routines on the 28X1.
For the most part this works well, but when receiving larger quantities of data I receive duff data. I assume this is because the TILP is so slow, the receive buffer is overflowing.
I tried to use the VMusic2 over SPI, but I have no idea what that entails so all I'm getting is a constant stream of zeroes from the device. Has anyone got it working over SPI?
I notice in Technical's sample code that VMusic2 pin 6 (CTS) is connected to PICAXE output 0. I've tried setting that high when sending to the TI then setting it low again afterwards, but to be honest I really have no idea what I'm doing or whether that helps in any way whatsoever.
Â
Â
