VL53L0X Time of Flight sensor
stan74
There was some talk about VL53L0X. I posted some picaxe code on gcb forum and a mmotte converted it.Cool. Did anyone get further?
I find it difficult to convert picaxe to gcb. This vid is my version of picaxe VL53L0X code converted to gcb
#chip mega328p, 16
#option Explicit
#include <glcd.h>
#include <uno_mega328p.h >
    #define GLCD_TYPE GLCD_TYPE_ILI9341
    'Pin mappings for SPI - this GLCD driver supports Hardware SPI and Software SPI
    #define GLCD_DC       DIGITAL_8         ' Data command line
    #define GLCD_CS       DIGITAL_10          ' Chip select line
    #define GLCD_RESET    DIGITAL_9         ' Reset line
    #define GLCD_DI       DIGITAL_12          ' Data in | MISO    - Not used therefore not really required
    #define GLCD_DO       DIGITAL_11          ' Data out | MOSI
    #define GLCD_SCK      DIGITAL_13          ' Clock Line
;now rename colours to make it easier to set up sprite data
#define bk ILI9341_BLACK
#define re ILI9341_RED
#define gr ILI9341_GREEN
#define bl ILI9341_BLUE
#define wh ILI9341_WHITE
#define pu ILI9341_PURPLE
#define ye ILI9341_YELLOW
#define cy ILI9341_CYAN
#define dg ILI9341_D_GRAY
#define lg ILI9341_L_GRAY
#define si ILI9341_SILVER
#define ma ILI9341_MAROON
#define ol ILI9341_OLIVE
#define li ILI9341_LIME
#define aq ILI9341_AQUA
#define te ILI9341_TEAL
#define na ILI9341_NAVY
#define fu ILI9341_FUCHSIA
'GLCD selected extension font set. ASCII characters 31-254, the extended font uses 1358 bytes of program memory
#define GLCD_EXTENDEDFONTSET1
GLCDfntDefaultsize = 1
GLCDRotate ( Landscape_Rev )
GLCDfntDefaultsize = 3
GLCDCLS ILI9341_BLUE
;set up v53l0x
#define HI2C_BAUD_RATE 400
#define HI2C_DATA PORTC.5
#define HI2C_CLOCK PORTC.4
HI2CMode Master
;main Get Distance-------
dim ptr,buffer(13) as byte
         HI2CStart ;software restart
          HI2CSend(0x52)
          HI2CSend(0x89)
          HI2CSend(0x01)
          HI2CStop
wait 200 ms
          HI2CStart ;Sys Range Start
          HI2CSend(0x52)
          HI2CSend(0x00)
          HI2CSend(0x01)
          HI2CStop
          HI2CStart
          HI2CSend(0x52)
          HI2CSend(0x14)
          HI2CReStart
          HI2CSend(0x53)               ;indicate a read operation
          For ptr =1 to 12
              HI2CReceive buffer(ptr), ACK
          next
          HI2CReceive buffer(13), NACK
          HI2CStop
GLCDDrawString 0,0,"Error "+str((buffer(2) and 0x78)/8)+"  ",wh
GLCDDrawString (0,40,"Distance: ",wh)
GLCDfntDefaultsize = 5
GLCDDrawString (0,120, str(buffer(11)*256+buffer(12))+"   mm  ",wh)
stan74
This is the code translation and a picaxe user will recognise their code that it got translated from.
;vl53l0x converted from picaxe
#chip 16F886,8
#option Explicit
#define W_ADDRESS 0xEC
#define R_ADDRESS 0xED
#define VL53Dev 0x52
HI2CMode Master
#define USART_BAUD_RATE 9600
#define USART_TX_BLOCKING
#define USART_DELAY 1 ms
dim VL52ByteValue as byte
dim VL52WordValue as word
dim DATABUFFER_POINTER as byte
'VL53L0x Registers Write and Read
'No.  Command Return value  Description
'1    0XA0    BYTE1,BYTE2   Word output mode, the output distance is (BYTE1 < 8) &BYTE2;
'                       the conversion to 10 is the actual measurement distance, the unit is mm
'2    0XA1    BYTE1,BYTE2   VL53L0X initialization (initialization time is 500mS)
'3    0XB0    0XB0      The module baud rate is set to 9600, and it takes effect in time (default)
'4    0XB1    0XB1      The module baud rate is set to 19200, and it takes effect in time
'5    0XB2    0XB2      The module baud rate is set to 115200, and it takes effect in time
'6    0XC0    0XC0      Set up as a long distance measurement mode (default)
'7    0XC1    0XC1      Set up as a high-speed measurement model
'8    0XC2    0XC2      Set to high precision measurement mode (measurement interval is greater than 180mS)
'9    0XD0    0XD0      Set XSHUT to high level, module work normally and initialize module
'10         0XD1          0XD1      Setting XSHUT to low level, VL53L0X closes
'11         0XF0            BYTE1--BYTE4          Current baud rate (MSB)
'                     BYTE5  0X00 long distance mode                                                    0X01 high speed measurement mode
'                            0X02 high precision measurement mode
'                     BYTE6  The status of the current XSHUT
dim da(14) as byte
'Symbol Da1        = b10
'Symbol Da2        = b11
'Symbol Da3        = b12
'Symbol Da4        = b13
'Symbol Da5        = b14
'Symbol Da6        = b15
'Symbol Da7        = b16
'Symbol Da8        = b17
'Symbol Da9        = b18
'Symbol Da10       = b19
'Symbol Da11       = b20
'Symbol Da12       = b21
'Symbol devError   = b22
'Symbol datoVL   = b23
'Symbol Distance   = w12
'Symbol Signal   = w13
'Symbol SPAD     = w14
'Symbol Ambient    = w15
dim devError,datoVL,tmp,addr,ctr as byte
dim Distance,Signal,SPAD,Ambient as word
;hi2csetup I2CMASTER, $52, i2cfast, i2cbyte
'do
;  hi2cin $C0,(b0)
    rd_byte_verVL53( VL53Dev, 0xC0, VL52ByteValue )
    HSerPrint "Device ID       0xEE           0x"
    HSerPrint hex(VL52ByteValue)
    HSerPrintCRLF
    wait 10 ms
;  hi2cin $C1,(b0)
    rd_byte_verVL53( VL53Dev, 0xC1, VL52ByteValue )
    HSerPrint "Address 0xC1    0xAA           0x"
    HSerPrintCRLF
    wait 10 ms
;  hi2cin $C2,(b0)
    rd_byte_verVL53( VL53Dev, 0xC2, VL52ByteValue )
    HSerPrint "Revision ID     0x10           0x"
    HSerPrintCRLF
    wait 1 s
' Soft reset
'hi2cout $89,($01)
    wr_byte_VL52 ( VL53Dev,0x89,  0x01 )
    wait 200 ms
'Sys range start
';hi2cout $00,($01)
    wr_byte_VL52 ( VL53Dev,0x00,  0x01 )
'Read 12 raw data of Sensor:
;hi2cin $14,(da1,da2,da3,da4,da5,da6,da7,da8,da9,da10,da11,da12)
rd_multi_verVL53  ( VL53Dev, 0x14, 12, Da() )
;sertxd (#da1," ",#da2," ",#da3," ",#da4," ",#da5," ",#da6," ",#da7," ",#da8," ",#da9," ",#da10," ",#da11," ",#da12,cr,lf)
for ctr=1 to 12
  hserprint str(da(ctr))+" , "
next ctr
hserprintcrlf
'Resolve sensor errors
devError = (Da(1) and 0x78)/8 ;>> 3 ' // Check for errors
hserprint "Status: "
;sertxd("Status: ")
;hserprint str(tmp)
;If devError = $00 Then  sertxd ("Data OK!") : endif  ' No device error
If devError = 0 Then hserprint "Data OK!"
;If devError = $01 Then  sertxd ("VCSEL CONTINUITY TEST FAILURE!") : endif
If devError = 1 Then hserprint "VCSEL CONTINUITY TEST FAILURE!"
;If devError = $02 Then  sertxd ("VCSEL WATCHDOG TEST FAILURE!") : endif
If devError = 2 Then hserprint "VCSEL WATCHDOG TEST FAILURE!"
;If devError = $03 Then  sertxd ("NO VHV VALUE FOUND!") : endif
If devError = 3 Then hserprint "NO VHV VALUE FOUND!"
;If devError = $04 Then  sertxd ("MSRC NO TARGET!") : endif
If devError = 4 Then hserprint "MSRC NO TARGET!"
;If devError = $05 Then  sertxd ("SNR CHECK!") : endif
If devError = 5 Then hserprint "SNR CHECK!"
;If devError = $06 Then  sertxd ("RANGE PHASE CHECK!") : endif
If devError = 6 Then hserprint "RANGE PHASE CHECK!"
;If devError = $07 Then  sertxd ("SIGMA THRESHOLD CHECK!") : endif
If devError = 7 Then hserprint "SIGMA THRESHOLD CHECK!"
;If devError = $08 Then  sertxd ("TCC!"): endif
If devError = 8 Then hserprint "TCC!"
;If devError = $09 Then  sertxd ("PHASE CONSISTENCY!") : endif
If devError = 9 Then hserprint "PHASE CONSISTENCY!"
;If devError = $0A Then  sertxd ("MIN CLIP!" ): endif
If devError = 10 Then hserprint "MIN CLIP!"
;If devError = $0B Then  sertxd ("RANGE COMPLETE!") : endif
If devError = 11 Then hserprint "RANGE COMPLETE!"
;If devError = $0C Then  sertxd ("ALGO UNDERFLOW!") : endif
If devError = 12 Then hserprint "ALGO UNDERFLOW!"
;If devError = $0D Then  sertxd ("ALGO OVERFLOW!") : endif
If devError = 13 Then hserprint "ALGO OVERFLOW!"
;If devError = $0E Then  sertxd ("RANGE IGNORE THRESHOLD!") : endif
If devError = 14 Then hserprint "RANGE IGNORE THRESHOLD!"
;sertxd (" (",devError,")",cr,lf)
hserprint "devError= "+str(devError)
hserprintcrlf
'Resolve info of sensor VL53L0x:
  'If devError = $00 or devError = $06 update Distance
  'If devError = $00 Or devError = $06Then
Distance=Da(10)*256+Da(11)
'endif
  'Effective SPAD Return Count
SPAD = Da(2) + Da(3) /255
  'Signal Rate
Signal = Da(6)*256+Da(7)
  'Ambient Rate
Ambient= Da(8)*256+Da(9)
'Send terminal info:
;sertxd ( "Distance: ", #Distance," mm",13,10 )
hserprint "Distance: "+str(Distance)+" mm"
hserprintcrlf
;sertxd ("Ambient ", #Ambient,"mc/s",13,10 )
hserprint "Ambient "+str(Ambient)+" mc/s"
hserprintcrlf
;sertxd ( "Signal Rate = ",#Signal,"mc/s",13,10 )
hserprint "Signal Rate = "+str(Signal)+" mc/s"
hserprintcrlf
;sertxd ( "SPAD = ",#SPAD,13,10 )
hserprint "SPAD = "+str(SPAD)
hserprintcrlf
wait 5 s
  sub rd_byte_verVL53( in VL53Dev as byte, in VL53Addr as byte, out VL53ByteVal as byte )
      ;read a single byte from an address
      #ifdef HI2C_DATA
          HI2CStart
          HI2CSend(VL53Dev)
          HI2CSend(VL53Addr)
          HI2CReStart
          HI2CSend(VL53Dev or 1)                   ;set the read flag
          HI2CReceive(VL53ByteVal, NACK)           ;read one byte and conclude
          HI2CStop
      #endif
      #ifdef I2C_DATA
          I2CStart                              ;generate a start signal
          I2CSend(VL53Dev)                       ;inidcate a write
          I2CSend(VL53Addr)
          I2CReStart
          I2CStop
          I2CAckPoll(VL53Dev)                ;wait for buffer write
      #endif
    end sub
    sub rd_word_verVL53( in VL53Dev as byte, in VL53Addr as byte, out VL53WordVal as word )
      #ifdef HI2C_DATA
          HI2CStart
          HI2CSend(VL53Dev)
          HI2CSend(VL53Addr)
          HI2CReStart
          HI2CReceive(VL53WordVal_h)           ;read one byte and conclude
          HI2CReceive(VL53WordVal, NACK)           ;read one byte and conclude
          HI2CStop
      #endif
      #ifdef I2C_DATA
          I2CSend(VL53Addr)
          I2CReStart
          I2CStop
      #endif
    end sub
    sub rd_multi_verVL53  ( in VL53Dev as byte, in VL53Addr as byte,  in  NumOfByteData as byte, out DataBuffer() )
      'NumOfByteData--
      #ifdef I2C_DATA
          I2CStart
          I2CSend(VL53Dev)                 ;Send address
          I2CSend(VL53Addr)
          I2CReStart
          I2CSend(VL53Dev+1)               ;indicate a read operation
          For DataBuffer_Pointer = 0 to (NumOfByteData -1)
              I2CReceive DataBuffer( DataBuffer_Pointer), ACK
          next
          I2CReceive BME280_DataBuffer( NumOfByteData ) , NACK
          I2CStop
      #endif
      #ifdef HI2C_DATA
          HI2CStart
          HI2CSend(VL53Dev)
          HI2CSend(VL53Addr)
          HI2CReStart
          HI2CSend(VL53Dev+1)               ;indicate a read operation
              HI2CReceive DataBuffer( DataBuffer_Pointer), ACK
          next
          HI2CReceive DataBuffer( NumOfByteData   ), NACK
          HI2CStop
      #endif
end sub
sub wr_byte_VL52 ( in VL52Dev as byte, in VL52Address as byte,  in VL52_SendByte as byte )
      #ifdef I2C_DATA
          I2CStart
          I2CSend(VL52Dev)                 ;Send address
          I2CSend(VL52Address)
          I2CSend(VL52_SendByte)           ;Send data
          I2CStop
      #endif
      #ifdef HI2C_DATA
          HI2CStart
          HI2CSend(VL52Dev)
          HI2CSend(VL52Address)
          HI2CSend(VL52_SendByte)
          HI2CStop
      #endif
end sub
stan74
thanks
I had seen
main: hi2cout 0x00,(0x01) ;and re-arm
pause 200
;read the range in mm from 0x1E
hi2cin 0x1E,(b3,b2)
w2 = b3
w2 = w2 * 256
w2 = w2 | b2
I posted a request to convert to gcb on their forum.
I have a proton basic v53L0X program I could not convert and a few c programs I can not follow.
The picaxe program I used is by Buzby, I think. I mentioned the device years ago and Erco took interest, then Buzby and you Hippy.
turns out hi2cin 0x1e,(b3,b2) would be
HI2CStart ;read distance
HI2CSend(0x52)
HI2CSend(0x1e)
HI2CReStart
HI2CSend(0x52 or 1) ;set the read flag
HI2CReceive(distance_hi) ;read one byte and conclude
HI2CReceive(distance_lo, NACK) ;read one byte and conclude
HI2CStop
which gives distance= distance_hi*256+distance_lo.
This is faster than reading 12 bytes unless you need the other registers info..like error codes
stan74
I'm now using 0x1e ...and 0x1f I suppose to read distance.
Seems I was reading an array of 12 bytes from 0x14 before and using elements 11 and 12.
Buzbys code I think. Gave lots of info.See above post.
It's a nice unit and no c needed. I fancy trying it on a robot instead of ultrasonic.
