Virtual terminal characters + thermocouple
davefish55
I am using VSM to simulate a MAX6675 into an 08M. I used PH Anderson's code as a starting point and wiring from tutorial 03. It seems to be working, however, I am wondering about how to simulate the thermocouple. I have tried to use a DC generator set at 16mV (this should be around 390C for a type-K). I've attached a JPG that shows the circuit. I didn't really see how to attach the DC generator to the 6675. The 6675 is outputting a temp of around 24.7C, which is about 1mV in.
Thanks.
davefish55
Solved
Should have played longer before posting. Replaced the DC generator with a DC voltage primative and that did the trick.
