Curious, does the Virtual Serial LCD panel only work on B.0? I can output serial data and view it in the Virtual Serial Terminal on many other pins across many Picaxe families but only B.0 brings up the LCD window. If so, is there a reason for this?
Thanks.
EDIT: Never mind and thanks anyway. I found the option in the 'Simulation' tab under 'Options'. Duh!
Thanks.
