builtliketexas
Is there any way to verify the programs on a PICAXE?
Or writ it into an unused variable and sertxd it to the PC at the start of the programme or some unique event.I've seen people use a spare output pin and have an LED flashing out the version number of the program on the chip. This isn't verification as such, but it can help when you simply can't remember exactly what you downloaded 5 and a half weeks ago...
This would not happen as the download:BB: I think the case would be when you have (say) a 1 bit 'flip' in a byte on the download and then the echo gets the same bit inverted. The PC thinks the byte downloaded OK but the code in the PICAXE contains an error.
