Verification error
jimruxton
Hi ,
I'm using the linux command line compiler and am getting this error message:
jim@jims-laptop:~/picaxe$ sudo ./picaxe28x1 -c/dev/ttyUSB0 test.bas
PICAXE-28X1 (40X1) Enhanced Compiler. Version 0.2
Copyright (c) 1996-2008 Revolution Education Ltd
All rights reserved.
www.picaxe.co.uk
Compiled successfully.
Memory used = 15 out of 4096 bytes.
Searching for hardware on /dev/ttyUSB0.
Downloading program.
line# 0 col# 0
Error:
Verification error - 0xFFFFFF82 transmitted but nothing received at byte 0
(err=11: Resource temporarily unavailable)
Any idea what would cause this? Could it be my USB to Serial converter? It seems to recognize when I disconnect the chip and there is no hardware there and recognizes it as a 28X1. Any thoughts?
Jim
This does seem to be an issue with the USB to serial adapter - is it a USB010 or an AXE027?
We have no experience of this device under Linux and hence can't provide any more support. Both the USB010 and AXE027 do work correctly.
