Hello everyone!
I've recently started working with the picaxe and thought I'd ask for some help
Problem: I have an input PWM signal that needs to be read by the picaxe. I'm only concerned about the frequency of said PMW signal, which can range for 1Hz to 10Hz. If I wanted to set a variable to the frequency how would I do that? I've briefly looked at the pulsin command; with no luck...
Overall I'm very new to basic coding and i've tried searching around with little results.
Thanks, Lachlan
P.S I'm using the 20M2
Thanks, Lachlan
