Jerry Silverthorn
Hi all !
I can't find anything on this subject using search - which is strange as I am sure it is (or was) very common.
Years ago I created a PICAXE-28 project to control a Pantomime CooCoo clock such that I could change the time and deploy the CooCoo as required. I used this BT_ADAPTER (HC-06) Bluetooth device then and it worked very well. But that was in Window 7 days. I think I used PuTTy as a terminal - but that doesn't work for this application in windows 10. (No connection options - device remains PAIRED but not CONNECTED)
I am having problems with windows 10 for a similar comms interface for a solar water heater project - I want occasionally to read data from the project board to see the water temp(s) and possibly to control the pump externally.
So given that things have moved on - is there a better way ? Better project board, better interface chip ?
Why can't I connect to the Bluetooth device (yesterday it was good - today after a windows update I had to reinstall the AXE-027 drivers and can't now connect to HC-06 even though it has successfully Paired.
Anyone got good experience of this - please help !!
