There's one way but it's not really practical nor reliable. A switch between Leg 2 and +V would cause the PICAXE to enter its download mode then after a while would restart the program entirely. By checking the value of a variable or SFR location it would be possible to tell if the program had reset or not. Problems however include -
The PICAXE will ignore the button push while in SERIN and INFRAIN.
The PICAXE will stop working while the button is held, and there may be a significant delay after the button is released to when it starts working again.
The I/O lines will be reset to their defaults.
The program will completely restart from the first code line with variables and SFR locations initialised to zero.
As a 'soft reset' such a button could be used, but as a responsive button as one would normally want it's not that useful.
PowerOn_Or_SoftReset:
Do
If b13 = 0 Then
Gosub Initialise
b13 = 1
End If
Gosub MainProgram
Loop
It's easy enough to experiment with, so you may want to give it a try if it looks appropriate for what you want.
