I want to use a MLX90614 infa red thermometer in a project but it requires some programming to set its output via SM Bus. Plenty examples with Arduino(not very familiar with) but none with Picaxe. The data sheet indicates a PWM/SDA pin can be programmed as a push-pull or open drain NMOS which can trigger an external device. I am a "Blank Slate" on how to even get started on this.
Any step by step advice would be helpful.
