Hi there,
I was wondering if someone could help me with regards to using the internal timer of an 18M2 chip. I'm currently using the chip to turn on different coloured LEDs when different inputs are turned on. Eventually I'll hook it up to 3 input devices which will be running for an hour and half process and if one of them turns off (which they shouldn't) then a red LED will display and also an OLED screen will display which input it is which has turned off.
However, I was hoping there might be a way of using the internal timer of the 18M2 chip to display exactly when this input 'failed' so that I can see how far along the process it did fail so that I know how much longer the process should be restarted from.
Sorry if there is an obvious explanation but I'm still new to this and could definitely use some help!
Thanks very much!
Jon.
Thanks very much!
Jon.
