I would like some feedback on this method of using C.0 (serial out) as an input . It works by connecting the DAC to the output pin, but not enabling the DAC . The pin is connected to VSOURCE+ through all the resistors in the resistor ladder by setting DACLPS = 1 and DACLEVEL to 0 . The bottom of the ladder is not connected to VSOURCE- . This is the low power setting so the ladder doesn't draw as much current . To use it as an input connect the pin to ground through a switch and 10K resistor . Use the READDAC command to determine if the switch is closed . The following test program returned readings of 250-255 with the switch open and 19-22 with it closed .
The voltage measured across the 9.8K resistor with the switch closed was .25 volts with a supply voltage of 4.3 volts . This comes out to .025 mA, so I don't think the pin is being loaded excessively . The datasheet shows 32 resistors of 5K each in the ladder . Using Ohms law, (4.3Volts - .25Volts) / .000025Amps = 162KOhms between the pin and VSOURCE+ . This is inline with the datasheet . I know this is not the intended use for the DAC, so I'd like other opinions .
Pertinent parts of PIC12lf1840 datasheet:
Section 17 for DAC
FIGURE 17-3 OUTPUT VOLTAGE CLAMPING EXAMPLES
REGISTER 17-1: DACCON0: VOLTAGE REFERENCE CONTROL REGISTER 0
Table 30-11 DAC electrical specs
I have included my test program and schematic .
Section 17 for DAC
'test using serout pin C.0 as an input by using dac
'connects C.0 pin to positive rail through all dac voltage divider resistors
'bottom of voltage divider is disconnected by setting DACEN = 0 , DACLPS = 1
'picaxe commands are
' daclevel 0
' dacsetup %01100000
'use readdac to get voltage on pin
'if switch is open reading will be near max (255)
'if switch is closed it will be near 0 (I got 20)
'refer to section 17.4 of pic12lf1840 data sheet for details
'built on AXE021 PICAXE-08 PROTO BOARD
'after programming set jumper to route C.0 to 10K resistor and switch
'jumper C.4 back to serout of programming socket for serial output
#picaxe 08m2
setfreq m4
'prepare c.4 for serout (idle low)
low c.4
serout c.4,n2400_4,("Start",13,10)
daclevel 0
dacsetup %01100000 'connect pin to positive rail through all resistors in ladder
here2:
readdac b0
serout c.4,n2400_4,(#b0,13,10)
if bit7 = 0 then 'if less than 128 then switch must be closed
serout c.4,n2400_4,("closed",13,10)
serout c.4,n2400_4,("open",13,10)
pause 500
goto here2
