Using Arduino IIC / I2C Serial 3.2" LCD 2004 Module Display
Pekari
Hi!
Has anyone used this LCD?
How it could get to work with PICAXE?
It uses address 0x27.
Does anyone have a example code how it could get to work?
Paste in here, thanks!
jinx
lol you posted an ardiuno here,picaxe should be able too talk too it see i2csetup, where's your code so far,or do you want someone else to do for you.where's the link to the data sheet
jinx
Pekari
I haven't found a datasheet, but bread board type is "LCM1602 IIC V1".
When I connect a power to LCD without data it show like this photo:
And I haven't get it show anything else.
Jamster
First thing I would do is try sending it 0 - 255 in order and see if it does anything.
Use a for loop, with a pause and some serout commands (to debug from the computer), then you can see which commands affect the LCD. :)
Note: This is probably not the way most would do it...
Jamster
The board has a PCF8574 i2c i/o expander on it.
This is a 'dumb' i2c-parallel chip with none of the intelligence of other more common serial LCD modules.
So basically you have to work out which on the 8 i/o pins are connected to which LCD pin and then completely hard code all the LCD control codes / initialisation routines.
That can be done, but all in all it would probably be much simpler to buy an 'intelligent' i2c or serial module like the AXE033 or AXE133.
Pekari
Thanks!
I found chip and LCD 20x4 datasheets.
(LCD datasheet isn't exactly right one.)
I will be happy if I can see even 1 caracter in this display! And I will be appreciative if someone will help on this project.
g6ejd
I don't see any difficuly in using this with a PICAXE as it's a I2C bus. Reference to the manual will give you the basic outline of how to communciation with it at address 27.
hi2cout 27,(254,1) ; clear screeen
hi2cout 27,("Hello World");
Use the same commands for the standard LED display driver chip such as HD44780, etc
You probably have to send a complete initialisation sequence like you do with a directly driven parallel interface. 'Black blobs' on line 1 and 3 of a four line display is symptomatic of the display not being initialised.
Pekari
I have used this code:
#picaxe 18m2
init:
	i2cslave 27,i2cslow,i2cword ' set up i2cslave for LCD
	pause 500 ' wait for display to initialise
	writei2c 0,(254,1) ; clear screen
	pause 200
	writei2c 0,("Hello World",255);
	pause 200
I also have try address $27 and i2cbyte.
Nothing happens...
nick12ab
#picaxe 18m2
init:
	pause 200
	pause 200
Nothing happens...
See technical's post:
As the i2c I/O expander only has eight I/O pins, the LCD will be controlled using the 4-bit interface and you have to send two bytes to pulse the Enable pin. This would be quite slow, very difficult to use, program memory hogging and generally not very good.
My view on this: This LCD combines the disadvantages of both intelligent serial (expensive) and 4-bit shift register serial (complicated) and with none of the advantages. It would be easier to do 8-bit shift register control with separate enable and register select lines.
nick12ab
Do I have to split address 27 to two part too?
I can't believe it's that complicated...
No. Only communications to the i2c port expander to control the LCD are. However you must first find out which pins on the port expander's port connect where on the LCD.
g6ejd
I've got to ask:
1. Have you connected the SDA (Data) line to the correct pin on the PICAXE? - - which pin on which device.
2. Have you connected the SCL (Clock) line to the correct pin on the PICAXE? - - which pin on which device.
Is there a link on the daughter board that might switch it between serial and I2C mode?
Do you have a data sheet for the screen controller?
Jamster
g6ejd: I don't think you understand... The chip in place is an IO expander, not an LCD driver... That means he has to use the 4bit interface through the I2c chip - not easy.
I think the easiest method would be to unsolder the chip add-on board from the LCD board then use the two seperately, the LCD with the normal 4bit interface and the I2c expander for something completely different.
Jamster
Pekari
@g6ejd:
I use PICAXE 18M2.
Pins are: SDA = pin 7 and SCL = pin 10.
Both pins have 5.1 k pull up-resistors to +Vcc.
You can see board in my post #1 and datasheets from my post #6.
@Jamster:
Ok, thanks. I think I'm maybe masochist when I buy this... I'm clad I didn't buy 3 pcs this display!!!
Still I try to found some use to this.
And I'm not sure if that LCD datasheet is exact, because there also exist 8-bit 20x4 LCD:s and I'm not sure if this is one of them.
This LCD is HJ204A. I did'n found exact datasheet.
Pekari
Now I'm trying with this code:
#picaxe 18m2
init:
	i2cslave 27,i2cslow,i2cbyte ' set up i2cslave for LCD
	hi2cout 0,(0,3)
	pause 10
	hi2cout 0,(0,3)
	pause 10
	hi2cout 0,(0,3)
	pause 200
	hi2cout 0,(0,3)
	pause 20
	hi2cout 0,(8,0)
	pause 20
	hi2cout 0,(1,0)
	pause 20
	hi2cout 0,(6,0)
Is this the right direction?
g6ejd
Yes.
The data sheet suggest the display starts in 8-bit mode. So you need to reverse your data as it's DB5 and DB4 that are the control bits, so: 0 0 1 1 x x x x is Hex 30 or &30
hi2out 0,(&30) ; & toi denote hex format
pause 10
hi2out 0,(&30)
pause 10
hi2out 0,(&30)
; no other initialisation required other than a clear screen maybe
pause 10
hi2out 0,("hello")
The data bits to use and send out will depend on how the PCF8574 to LCD interface is wired on the module.
It will also be necessary to control all of the LCD control lines and in the correct sequence; for example, send Data and RS with E low, then the same with E high, and finally the same with E low again. So to 'send one byte to the LCD' will likely require four bytes to be sent over I2C because it is in 4-bit mode.
Note that the PCF8574 doesn't use an 'address' in the data sent to write to the display, but using 0 should not cause problems as that simply sets all outputs low. Alternatively the first byte of I2C data could be sent as the address.
The most sensible way to do this is to use standard PICAXE to parallel interfacing code, alter the 'init', 'wrdat' and 'wrcmd' parts to send via I2C rather than output directly to the port. This is the classic 'hardware abstraction' approach and will be far easier than changing all the code throughout a program. That can be done when it's all working if it's felt necessary to do so.
Added: The first step is to determine the PCF8574 to LCD signal wiring. Without that you cannot write the PICAXE I2C code.
Pekari
Now I try with this code:
#picaxe 18m2
init:
	hi2cout 27,($30)
	pause 10
	hi2cout 27,($30)
	pause 10
	hi2cout 27,($30)
	pause 200
	hi2cout 27,($30)
	pause 20
	hi2cout 27,($8)
	pause 20
	hi2cout 27,($1)
	pause 200
	hi2cout 27,($4)
	pause 200
	pause 200
Nothing...
Circuit:
You still havent grasped that this is not an intelligent driver, and so you will *never* be able to do something like:
To use this unit you will have to write complex unique subroutines to initialise the screen in 4 bit mode, and then to send each character or each control code one by one (ie a i2c command for each of the two 4 bit nibbles, and another i2c command to pulse E in between each nibble).
Once again, it will be much, much easier to ditch this unit completely and buy a serial controller instead if you want to use the type of command structure you are currently attempting to use.
Could AXE132 drive this LCD?
Very probably, but it's worth looking at the AXE134Y 20x4 OLED which seems comparably priced to what you have. It will be very much easier to interface to using serial.
Just for amusement; to send "Hello World" to this I2C display would require something like -
HI2cOut $14, ( $34, $14, $18, $38, $18, $16, $36, $16, $15, $35, $15, $16, $36, $16, $1C, $3C, $1C, $16, $36, $16, $1C, $3C, $1C, $16, $36, $16, $1F, $3F, $1F, $17, $37, $17, $17, $37, $17, $12, $32, $12, $10, $30, $10, $15, $35, $15, $17, $37, $17, $16, $36, $16, $1F, $3F, $1F, $17, $37, $17, $12, $32, $12, $16, $36, $16, $1C, $3C, $1C, $16, $36, $16, $14, $34, $14 )
That's a full 113 bytes or so compared to the 24 used for serial output, and you have to work out what each byte to send is.
That's obviously not the way to have to do it. Applying hardware abstraction would allow just the output routines to be written similar to below. The SYMBOL commands have to be set right and you mustn't use 'b1' elsewhere in the code. Every byte sent to the display has to be via a call to one of the two routines. That's far less efficient or as easy to use as serial.
Symbol bitD0 = bit8
Symbol bitD1 = bit9
Symbol bitD2 = bit10
Symbol bitD3 = bit11
Symbol bitRS = bit12
Symbol bitE  = bit13
SendB0AsCommandByte:
  bitRS = 0
SendB0AsDataByte:
  bitD0 = bit4      ; Send msb first
  bitD1 = bit5
  bitD2 = bit6
  bitD3 = bit7
  bitE  = 1
  b2    = b1        ; b2 holds msb with E set
  bitE  = 0         ; b1 holds msb with E clear
  HI2cOut b1, ( b2, b1 )
  bitD0 = bit0      ; Send lsb second
  bitD1 = bit1
  bitD2 = bit2
  bitD3 = bit3
  bitE  = 1
  b2    = b1        ; b2 holds lsb with E set
  bitE  = 0         ; b1 holds lsb with E clear
  bitRS = 1         ; Send data byte next time
  Return
Pekari
Thank you VERY MUCH, hippy!
I need to learn something about that code.
I added writable text to eeprom and then read value to b0 from there.
But I haven't get initialised this display because nothing happens.
Maybe next I need to learn how to clear display.
No, you need to determine what the PCF8574 signal connections are to the LCD, need to work out which bits control which LCD signal. Without that you won't likely be going anywhere.
Pekari
Isn't the LED controlled manually by the jumper link on the back?
Yes, but still it doesnt light when that code is working. In start it will flash but go off when program starts.
 HI2cSetup I2CMASTER, $4E, I2CSLOW, I2CBYTE
  b0 = $33 : Gosub SendB0AsInitByte 'LED will go off in this line of code.
nick12ab
Does the backlight come on if you use b0 = $3B ? If yes, then that means that P3 is actually connected to a transistor that controls the backlight.
nick12ab
No, it will not light with that.
"It will not light with that" sounds like an assumption rather than fact. Did you actually try it?
Is there a transistor controlling the backlight? Where does it connect to? Remember that if it's bipolar then there will be a base resistor which will make the continuity checker report no continuity.
Pekari
Of course I have try it! How else I could say that?
I also try put it to next line too. I have put command "end" to next of that line to see if LED will stay light.
There may be transistor on the other side of board, but I can't measure it because there isn't space so much.
Jumper link is connected to Vcc and controlling is in kathode side.
Pekari
There IS some transistor in the other side of LCM1602 IIC V1 -board but I don't know if it is controlling it and I can't measure it like I wrote.
I check the circuit:
LED controller is in the green board, not this little black board where that transistor is.
In green board aren't any transistor. There is these 5 IC and 8 resistors which must control backlight LEDs.
nick12ab
Can you desolder the black board from the connector?
