Oh, right. Didn't really expect to see a battery in such a circuit...
Well, to tell you the truth both this IC and the stepper are from an old printer. Couldn't find much more about this IC, and I've only found data concerning a higher DC-resistance variation of the motor that I have - those have ratings both at 12V and at 24V, so I suppose any voltage will be good enough. Mine is rated at 1.8ohm DC resistance, hence the need for a driver with constant current. Since this is more or less an exercise for me, I can't afford to shell out cash for a high current driver or another motor. Also, it seems to be a bit ridiculous, as even at 12V it would probable make a lot of heat.
Oracacle, PIN 27 is used to set the chopping freq according to this equation f=1 / 0.72 *Ct * Rt. As I understand, inputs 1 and 2 control one H bridge, and 3 4 control the second bridge, so essentially nothing would happen, if In1 was high and In4 was low, as it would only affect half of one H bridge and another half of another H bridge. I don't know if you googled another datasheet, but mine has the truth table (I've seen another one without some of the data). If I misunderstood your comment, please correct me.
JimPerry - so I just connect 2, 7, 21 to my 5V source (linear regulator) and be done with it?
I would probably run all of this from a PC PSU, would 5V from it be good enough as a reference voltage/supply source for all of these 5V inputs? Or should I run everything from 12V rail and use a 5V linear regulator?
