Use interrupts with VSM?
jims
#2
Talking to myself
I believe that I need to explain why I asked about "interrupts in VSM". Have been trying (unsuccessfully) to make this code work with the attached VSM schematic. Probably overlooking something obvious. Really do need some help.
	'#PICAXE 20M2 controller.U2,
symbol int_req=pinC.1	'C.1 (pin 9).
symbol RLED=B.3		'B.3 (pin 15).
symbol GLED=B.2		'B.2 (pin 16).
#picaxe 20m2
setfreq m4
pause 1000		'Pause to initialize system
pause 30
setint %00000010,%00000010	'Enable interrupt ON; C.1 (pin 9).
idle:			'######################################
			'#Routine waits for interrupt request
			'#from U1 on C.1 (pin 9).
 	 high RLED		'Turn RLED ON.
 	 pause 100
interrupt:		'##Interrupt detected.
  	low RLED		'Turn RLED OFF if get interrupt.
  	 pause 500
	high GLED		'Turn GLED ON if rcv serial data.
  	low GLED		'Turn GLED OFF if get this far.
 	 pause 500
Thanks in advance...Jims
#3
The SETINT demo provided with VSM seems to work.
Please post your .DSN and .BAS files and we can see what happens when we run those.
#5
There does seem to be a 20M2 interrupt issue on C.1 or C.2 in VSM, the other pins (C.3-C.5) work as expected.
Sorry about that, we'll have to look into it. The real chip will be fine.
If possible try VSM simulating on C.3, C.4 or C.5 instead for now.
jims
#6
Thank you. Tried C.3 & it now works "like a charm". Figured there must be a VSM problem since C.1 worked on a real-life bread board circuit & on the PE simulator. Jims
jims
#9
Tried it & the patch works "as advertised". You folks sure give great customer service. Our decision to use PICAXE was the right one!!!
Jims
Thank you "technical". I've downloaded the patch but haven't had time to check it yet. Jims
