Some further thoughts on your download problem:
Having a download prematurely stopped at the same point each time can often be caused by a dial-up ISP ‘pulling the plug’ on the connection –either for reasons of connection-time, or data transfer volume limits being reached. Have you recently changed your dial-up plan with your ISP, or has your ISP changed the terms & conditions of your plan without your knowledge?
You also mentioned that you are now using a different computer because the previous one was damaged by lightning. Have you considered the possibility that your modem was also damaged at the same time? I have seen many modems affected by lightning, & when damaged, they don’t all misbehave in the same manner.
BTW: PC’s are pretty much commodities these days -which is why IBM decided to get out of the business & sell their entire PC division to Lenovo of China. And even before the Lenovo buyout, IBM PC’s had mostly been built by contracting companies -which is not too different to the Dell business model, as all the parts of Dell computers are made by outside contractors also. In terms of reliability, I wouldn’t rate one above the other.
But if I were taking a guess, I would think that perhaps it’s more likely that the general unreliability of your current computer is related to the malware infestations that you briefly described. Maybe a total fresh software re-install may resolve these issues.
Incidentally, there is no 100% guaranteed protection against internet malware nasties at the moment, particularly with the increasing amount of ‘rootkit’ type of infections -which the current generation of anti-virus products can’t even detect! Note that because of the ‘always-on’ nature of Broadband, users with this form of connection are generally at greatest risk for malware, but if your computer is online for hours of long downloads via dial-up, then the risk will be similar.
Best defence is to keep your XP service packs & AV definitions up to date, and NEVER turn off your firewall!
Regards
Edited by - whizzer on 03/06/2006 18:08:34
