Update from USB?
#1
Is it possible to build a PICAXE project that will automatically update its program if a valid file is present on a USB drive?
I does not hurt to plan ahead!
#2
Technically possible if using a 28X2 or 40X2 with an external I2C EEPROM but rather tricky and a convoluted process with the risk that something could go wrong and you'll have to reprogram via serial to recover the situation.
I believe there has been past discussion on doing those on the forum. My opinion is that it likely wouldn't be worth the effort.
