Unused pins
pjrebordao
I remember reading sometime ago that an unused pin on a PICAXE (I'm using an 08M), shouldn't be left "loose", but can't remember what to do...
Should it be tied to the ground or 5V ?
It depends on the application -these are not CMOS logic gates!In general unused pins can be left floating, but there may be power savings in some cases if pins are tied hi/lo. <b>What are you doing? </b>
Simple LED flashing/sounds/datacomms PICAXE circuits are not fussy,but READADC stuff can be due to stray signals. A weak but firm pullup/down via 10k Ohms is then usually attached to a pin. Of course you can force pins high or low under software too.
HTH ? Stan
Edited by - manuka on 29/08/2007 02:57:16
<A href='http://www.rev-ed.co.uk/picaxe/forum/search.asp' Target=_Blank>External Web Link</a>
and see this =&gt;<A href='http://www.albinoblacksheep.com/flash/posting' Target=_Blank>External Web Link</a> to understand why
Thanks Stan.
Some additional info: The unused pin will be Input3, so it can't be made an output. The lowest power consumption is also a requirement, so should it be better to tie it to ground or 5V ?
The answer is &quot;yes&quot;.
Whatever is closest on your circuit board. The input has a high impedance, once tied to either rail it will consume nanoamps (or less).
Back
