Whilst the SRF005 is a very nicely built module, I wanted to build a system myself.
The system is based on the one outlined on this page: http://www.siliconchip.com.au/cms/A_103243/article.html
However I have customised the circuit. Input amplification means the system has a range of more than a metre, as opposed to just 120mm. Once calibrated, the system is accurate to approx 7mm. The free running oscillator has been completely changed and now gives a more stable 40kHz output. The program has had a couple of changes too.
The transducers are generic ultrasound ones, and output is via an LCD screen.
The circuit schematic is attached.
#picaxe08m
symbol receiver = 1
symbol receiver_in = PIN1
symbol receiver_high = %00000010
symbol receiver_low = %00000000
symbol transmitter = 4
symbol transmitter_high = %00010000
symbol transmitter_low = %00000000
symbol sample_count = w0
symbol time_to_echo = w1
symbol burst_time = w2
symbol distance = w3
symbol minimum_value = 30
charge:
gosub clearlcd
serout 2,N2400,(254,192,"Initialising...")
pause 100
let dirs = receiver_low + transmitter_high
let pins = receiver_high + transmitter_high
charge_loop:
output receiver
input receiver
if receiver_in = 0 then charge_loop
let pins = receiver_low + transmitter_high
discharge_pulse:
output receiver
input receiver
let sample_count = 0
discharge_loop:
if receiver_in = 1 then discharge_pulse
let sample_count = sample_count + 1
if sample_count < 30 then discharge_loop
gosub clearlcd
serout 2,N2400,(254,192,"Scanning...")
low transmitter
input transmitter
pulsin receiver,0,time_to_echo
high transmitter
if time_to_echo = 0 then no_echo
low transmitter
input transmitter
pulsin receiver,1,burst_time
high transmitter
let time_to_echo = time_to_echo + burst_time
no_echo:
let distance = distance / 10
gosub clearlcd
if w3 > minimum_value then
serout 2,N2400,(254,128,#w3,"mm ")
serout 2,N2400,(254,192,"No Response")
goto charge
clearlcd:
serout 2,N2400,(254,192," ")
pause 30
