ULN2803 inputs
Welcome to the PICAXE Forum
You cannot connect outputs directly ( or rather shouldn't ), but you can put a diode in each output line to create a diode-OR gate. Anodes to PICAXE, cathodes joined, to ULN.
john thorne
Thanks
Thanks for the quick reply. That will work for me.
If you have outputs to spare in the ULN2803, then you don't have to use diodes. Use the open collector darlington transistors in the ULN2803.
Connect 3 PICAXE outputs to 3 inputs on the ULN2803. Then common the 3 associated darlington collectors together. The load, of course, will go between the +ve rail and the collectors. Turning on any darlington will energise the load.
Finally, there is another alternative: do the "or" function in software and use a spare PICAXE output to drive a single darlington.
Buzby
An example of two different interpretations of the OPs original text - "outputs from 3 picaxe 18m2".
My interpretation was 3 seperate 18M2 chips, not 3 pins on one chip.
Obviously the software 'or' function will only work for 3 pins on one chip.
The diode option, or the 'commoned collector' option, will work on both single and multiple PICAXE chips.
This is the way we would also recommend. Remember to link all 0V rails together.
