rigidigital
I'm not sure that I can be helped with the little info I can provide but here goes.
I found a data sheet on the web and hooked up the receiver and transmitter as it says or as best as I can figure!
There are four leds which are switching without the transmitter even being on, so I am now reading the values of 'serin 3,T2400,serdata' to the pc screen.
The immediate concern is why so many values change when the transmitter is off...or just transmitting a static number. I dont even think its working, could my wireless d-link be interfering?? Are bits of hookup wire acceptible antenna. The four leds flash a lot less when I hold the antenna.
I would really like to get this running , I can be much more specific if anyone can help.
the output is below and the receiver code---->
'Start CODE ,Radio Control - Receive
symbol serdata = b0
output 0
output 1
output 2
output 4
aloop:
pins = serdata
pause 500
sertxd ("the value of b0 is --> ",#serdata,cr,lf)
goto aloop
'END CODE
THE OUTPUT
the value of b0 is --> 0
w?v?#?WW#?;vN##.????9#?253
w?v?#?WW#?;vN##.????9#?7
w?v?#?WW#?;vN##.????9#?49
w?v?#?WW#?;vN##.????9#?27
the value of b0 is --> 48
w?v?#?WW#?;vN##.????9#?15
the value of b0 is --> 2
w?v?#?WW#?;vN##.????9#?251
I have used receiver module RXB1 315/434 Mhz and its corresponding transmitter.
symbol serdata = b0
output 0
output 1
output 2
output 4
aloop:
pins = serdata
pause 500
goto aloop
'END CODE
THE OUTPUT
