WhiteSpace
Well-known member
Happy New Year all (I think it’s still just about OK to say that mid-Jan). Is it possible to have two-way IRIN/IROUT? So Picaxes A and B at opposite ends of a room. A can send to B and B send to A. Presumably there is a risk that even if you shield the IR LEDs so that the A transmitter and A receiver don’t have a clear line of sight, A would read transmissions sent by A and bounced back from walls etc. If I understand correctly, a Picaxe must be identified as device ”1” so it’s not possible to allocate different IDs to A and B. Is it a question of setting an initial byte in the transmission like a qualifier in serial, that only the other Picaxe will act on? Or is it as simple as the Picaxe not receiving while it‘s transmitting? I’ll play around a little and try these, but just wondered if I’m reinventing the wheel. Thanks.
