Two pin infrared receiver connection
johndxmurphy
I want to connect a two pin infrared receiver but don't how to connect to Picaxe input pins. I've seen plenty of examples using the three pin receiver. Any help would be appreciated. Thanks
BeanieBots
Depends on what type you've got.
Could be as simple as a pullup resistor, might need a whole lot more.
Part number? Datasheet?
BeanieBots
If that's the type you've got, then yes. Worth a try.
If nothing happens, then you'll have to get the datasheet and read.
