Code for control of DC motor using back emf using 18m2.
Works very well.
This uses 18m2. Use NOT gate for motor direction (I used a couple of transistor but you can use 7404).
See for circuit see here.
This is part of a larger project I am working on but I thought I would share.
Anobium
Works very well.
Controls two DC motors via L293D
Bi-directional feedback
Each motor is controller independently
Feedback used to ensure motor is at correct speed and to adjustment to ensure each wheel is at the same speed
Anobium
' BackEMF
' See http://frontrangerobotics.org/PIDbackEMF/DavesBEMFmotorArticle.htm
#rem
ÚÄÄÄÄÄÄÄÄ¿
10k POT to adjust delay c.2 > ³1 18³ c.1 < Switch input. Up btn
c.3 ³2 17³ c.0 < Switch input. Down btn
(not used) Serial In c.4 ³3 16³ c.7 < Direction change button
c.5 ³4 15³ c.6 > Motor 2 Information LED
-------- 0v ³5 14³ +5V --------
Motor 1 Dir to NOT gate&L293D b.0 < ³6 13³ b.7 < Motor 2 EMF #1
Motor 1 EMF #1 b.1 > ³7 12³ b.6 > Motor 2 Speed Out via PWM
Motor 1 EMF #2 b.2 > ³8 11³ b.5 < Motor 2 EMF #2
Motor 1 Speed Out via PWM b.3 < ³9 10³ b.4 > Motor 2 Dir to NOT gate&L293D
ÀÄÄÄÄÄÄÄÄÙ
#endrem
#picaxe 18m2
#define serial_debugx
setfreq m32
#no_data
#terminal 38400
' Assign Input/Output pins
symbol modeUp_btn = pinc.1 'INPUT from physical PIN 4;
symbol modeDn_btn = pinc.0 'INPUT from physical PIN 3;
symbol dir_btn = pinc.7 'INPUT from physical PIN 3;
symbol motor1_dirport = b.0: output b.0
symbol motor1_EMFport1 = b.1
symbol motor1_EMFport2 = b.2
symbol motor1_pwmport = b.3
symbol motor2_dirport = b.4
symbol motor2_EMFport1 = b.7
symbol motor2_EMFport2 = b.5
symbol motor2_pwmport = b.6
symbol delay_pot = c.2
symbol motor1_tempDuty = W1
symbol motor2_tempDuty = W2
symbol motor_stall1 = b6
symbol motor_stall2 = b7
symbol motor1_Direction = b8
symbol motor2_Direction = b9
symbol motor1_pulseCount = b10
symbol motor2_pulseCount = b11
symbol motor_stall = b12
symbol motor1_Duty = W11
symbol motor2_Duty = W12
symbol stallvalue = 10
symbol minDuty = 450
symbol mtr_off = 0
symbol mtr_fwd = 1
symbol mtr_rev = 2
symbol motor1_mtr_off = mtr_off
symbol motor1_mtr_fwd = mtr_fwd
symbol motor1_mtr_rev = mtr_rev
symbol motor2_mtr_off = mtr_off
symbol motor2_mtr_fwd = mtr_fwd
symbol motor2_mtr_rev = mtr_rev
motor1_Duty = minDuty 'Start with medium duty
motor2_Duty = minDuty
motor1_Direction = motor1_mtr_rev
motor2_Direction = motor2_mtr_rev
gosub change_direction_init
' main loop
If modeDn_btn = 1 and modeUp_btn = 0 Then
gosub Less ' if Less depressed
if motor1_Direction = motor1_mtr_off then
motor1_Direction = motor1_mtr_fwd
end if
end if
If modeDn_btn = 0 and modeUp_btn = 1 Then
gosub More ' if More depressed
end if
end if
If modeUp_btn = 1 and modeDn_btn = 1 Then
gosub Dark ' if both pushbuttons depressed
end if
' check motor is moving
gosub motor1_state
gosub motor2_state
readadc10 delay_pot, w13
w13 = w13 * 10
pause w13
motor1_state:
gosub motor1_readadcval
motor_stall1 = motor_stall
if motor_stall < 2 then
if motor1_tempDuty = 0 then
motor1_tempDuty = motor1_Duty
end if
if motor1_pulseCount = 0 then
motor1_tempDuty = motor1_tempDuty + 15
end if
inc motor1_pulseCount
if motor1_pulseCount = 3 then
end if
if motor1_tempDuty > 984 then
motor1_tempDuty = 984
end if
#ifdef serial_debug then
sertxd ("+",#motor1_tempDuty)
#endif
PWMOut motor1_pwmport, 249, motor1_tempDuty
'set speed to programmed speed
if motor1_tempDuty > motor1_Duty then
motor1_tempDuty = motor1_tempDuty - 15
sertxd ("-",#motor1_tempDuty)
#endif
PWMOut motor1_pwmport, 249, motor1_Duty
motor1_tempDuty = 0
end if
end if
sertxd (13,10)
#endif
motor2_state:
gosub motor2_readadcval
motor_stall2 = motor_stall
if motor2_tempDuty = 0 then
motor2_tempDuty = motor2_Duty
end if
if motor2_pulseCount = 0 then
motor2_tempDuty = motor2_tempDuty + 15
end if
inc motor2_pulseCount
if motor2_pulseCount = 3 then
end if
if motor2_tempDuty > 984 then
motor2_tempDuty = 984
end if
sertxd ("+",#motor2_tempDuty)
#endif
PWMOut motor2_pwmport, 249, motor2_tempDuty
if motor2_tempDuty > motor2_Duty then
motor2_tempDuty = motor2_tempDuty - 15
sertxd ("-",#motor2_tempDuty)
#endif
' adjust motors if they are rotating at different speeds
if motor_stall1 > 2 then
' sertxd ("adjust",#motor_stall1, " - ", #motor_stall2)
if motor_stall2 < motor_stall1 then
motor_stall = motor_stall1 - motor_stall2
motor2_Duty = motor2_Duty + motor_stall
' sertxd (" +:",#motor_stall)
if motor_stall2 > motor_stall1 then
motor_stall = motor_stall2 - motor_stall1
motor2_Duty = motor2_Duty - motor_stall
' sertxd (" -:",#motor_stall)
end if
PWMOut motor2_pwmport, 249, motor2_Duty
motor2_tempDuty = 0
end if
end if
sertxd (13,10)
#endif
motor1_readadcval:
PWMOut motor1_pwmport, 0, 0
select motor1_Direction
case motor1_mtr_off
' motor is off
motor_stall = 255
case motor1_mtr_fwd
readadc motor1_EMFport1, motor_stall
sertxd ("M1P1:")
#endif
case motor1_mtr_rev
readadc motor1_EMFport2 , motor_stall
sertxd ("M1P2:")
#endif
end select
sertxd ("ms=",#motor_stall)
#endif
motor2_readadcval:
PWMOut motor2_pwmport, 0, 0
select motor2_Direction
case motor2_mtr_off
' motor is off
motor_stall = 255
case motor2_mtr_fwd
readadc motor2_EMFport1, motor_stall
sertxd ("M2P1:")
#endif
case motor2_mtr_rev
readadc motor2_EMFport2 , motor_stall
sertxd ("M2P2:")
#endif
end select
#endif
change_direction:
If dir_btn = 1 Then
change_direction_init:
if motor1_Direction = motor1_mtr_rev then
high motor1_dirport
' same direction as motor 1
high motor2_dirport
motor2_Direction = motor1_mtr_fwd
elseif motor1_Direction = motor1_mtr_fwd then
low motor1_dirport
low motor2_dirport
motor2_Direction = motor1_mtr_rev
end if
motor1_tempDuty = 0
motor2_tempDuty = 0
end if
Less:
if motor1_Direction <> motor1_mtr_off then
motor1_Duty = motor1_Duty - 30 ' otherwise decrease duty
end if
if motor2_Direction <> motor2_mtr_off then
motor2_Duty = motor2_Duty - 30 ' otherwise decrease duty
end if
If motor1_Duty <= minDuty Then
end if
If motor2_Duty <= minDuty Then
end if
sertxd ("L: ",#motor1_Duty, 13,10)
#endif
motor1_tempDuty = 0
motor2_tempDuty = 0
More:
If motor1_Duty > 984 Then
return ' maximum Duty ceiling
end if
If motor2_Duty > 984 Then
end if
motor1_Duty = motor1_Duty + 30 ' otherwise increase duty
end if
if motor2_Direction <> motor1_mtr_off then
motor2_Duty = motor2_Duty + 30 ' otherwise increase duty
end if
sertxd ("M: ",#motor1_Duty, 13,10)
#endif
motor1_tempDuty = 0
motor2_tempDuty = 0
Dark:
PWMOut motor1_pwmport, 0, 0 ' zero the period (FULL STOP/DARK)
motor2_Direction = motor2_mtr_off
PWMOut motor2_pwmport, 0, 0 ' zero the period (FULL STOP/DARK)
