Hi
I think these two Blockly programs should work in a similar way.
Simulation works fine with both of them.
I use the same Remote and circuit in both programs.
Images show Code Explorer after pressing [7] key.
Program #1 works fine.
In the second program:
- I get error codes (Code Explorer) when running it.
(b3 takes the wrong value 1)
- If I uncheck "use timeout", there is no problem.
- If I delete the if-then-elseif-then block, there is no problem.
- If I reduce the if-then-elseif-then block to if-then block, there is no problem.
I don't know what is happening.
