Andrew Cowan
I've got a source (a GPS)of True baud serial data (T4800) that I want to look at on a PC. However, all the serial terminals I have tried want N (inverted data) it seems. Without using a hardware solution, is it possible to view the true data on a PC? It's only to check the NMEA strings - the PICAXE happily receives and decodes the data.
Any ideas for serial terminals that allow inversion?
Andrew
Andrew
