Troubleshooting Challenge
I got a set up here that I can't seem to see what is wrong.
Scenario: I am trying to add a rapid fire for my xbox 360 controller using picaxe 08M. The xbox 360 controller works on 2x1.2 rechargeable battery. Im trying to rapidfire Left Button. The schematic as follows
Considerations:
Left & Right Button is triggered when ground is applied.
Left & Right Trigger is triggered when +V is applied.
To trigger the Button again, ground should be removed and applied again.
To trigger the Trigger again, +V should be removed and applied again.
Result so far:
The code above works as a rapid fire for Left Button after the code download. But after a few minutes it also triggers the Right Button. Some instance it triggers Left Trigger. I have a feeling that the 2x1.2 rechargeable battery is the culprit or maybe just my code. Thanks for the help.
P.S. Cheating on the game is not my goal, its just a motivation.
'Rapidfire 360 Controller
input 2
do while pin3 = 1
input 1
pause 50
low 1
pause 50
high 1
Result so far:
