I'm using a common-anode RGB LED with each leg (besides power, of course) to a separate PWM channel (PICAXE 20M2), and each leg has its own proper resistor value. Link to the LED Datasheet
Issuing the initial "pwmout" commands result in the desired brightness of each internal LED, but where the issue comes in trying to turn off any color after that first pwmout.
Here's a simple test program, using only a single LED as a test:
If I am to understand the pwmout command correctly, to end a signal I use a pwmout command, the desired pin, and then "OFF"
Instead of turning off, what happens is the LED actually gets brighter when the "OFF" code is issued.
This is horribly frustrating and honestly quite confusing, especially since it's with something that seemingly should be quite simple.
init:
symbol RED_LED = c.3
pwmout pwmdiv4, RED_LED, 249, 599
wait 1
pwmout RED_LED, OFF
wait 1
