Natalie Wilkie
Hi All,
I intend to have a picaxe 28x1/40x1 controlling a 5 digit 7 segment led counter, it counts in 1 second increments using a DS1307 ic. The leds are driven by decoder/latch drivers.
I would like to be able to control (start, pause, reset, resume etc) it remotely, say up to 60 odd metres away and maybe through a thin dividing wall. I don’t want to use an infrared sensor I was more thinking of using an RF transmitter & receiver 433Mhz modules something like this: http://www.computronics.com.au/module/txrxpair/
From what I have read when using the serin and serout commands no other commands are executed (is this right) and this would interrupt my counting or/and slow things down and I need responses to happen quickly and reliably.
I intend to have a 08M controlling the transmitter and at the other end another 08M controlling the receiver and then this 08M receiving the data feed inputs of the 28x1/40x1.
My question is:
Is this over the top, will it work, will it ensure that the response from the transmitter will happen more quickly as this is all that the receiver 08M has to do?
Constructive criticism is most welcome.
Nat
My question is:
Nat
