I would be most grateful for some guidance from the experienced forum experts with this project. I intend linking two PICAXE 40X2s via a serial link over XBee transceivers. My aim is to map PORT D as inputs on one unit to PORT B as outputs on the other. This arrangement to apply both ways; i.e. Press-buttons on PORT D on unit one map to PORT B on unit two and the buttons on PORT D on unit two map to PORT B on unit one. The rate of switching is very low - indeed almost occasional. I think that this can be achieved using the hardware serial ports on the 40X2 devices, but, although I am very familiar with the use of SERIN and SEROUT and PICAXE in general, I am having some trouble understanding the depths of the hardware serial commands.
The problem is that I cannot use the simulator to check the operation of the program because the hardware serial function is not simulated. So before I commit a soldering iron to a stripboard, could I request comments on the viability of this concept and my proposed code?
'Serial transceiver switching using XBee and 40X2
'Hardware serial output on pin C.6
'Hardware serial input on pin C.7
#picaxe 40X2
#no_data
setfreq m16
SYMBOL REQUESTED_OUTPUT = b0 'reserve w0 and w1 for handling incoming serial data sent to PORT D
symbol port_switches = b4 'reserve w2 and w3 for handling local switch data from PORT B
SYMBOL last_switches = b5
hsersetup b2400_16,%001 '2400 Baud - True IN & True OUT - Background Receive On -
setintflags %00100000,%00100000 'Interrupt on background serial input
let dirsb = $FF ' set Port B as outputs
let pinsb = $00 ' initialise Port B outputs low
let dirsd = $00 ' set Port D as inputs
#macro send_switches
hserout 0,(PORT_SWITCHES) 'transmit value to XBee transceiver
Last_switches=port_switches 'record last switch change
do until pinsd=$00
pause 100 'pause to debounce switch return
#endmacro
interrupt:
pause 50 'Is this needed?
let ptr=0
get ptr, REQUESTED_OUTPUT
let pinsb = REQUESTED_OUTPUT
flags = 0 'Clear interrupt flags
hserptr = 0 'Reset pointer
setintflags %00100000,%00100000 'Reset interrupt on background serial
MAIN:
DO
let port_SWITCHES = pinsD
pause 100 'Debounce switches
if port_switches>0 then EXIT
send_switches
LOOP
