Touch Screen
RustyH
Good Morning,
I was wondering if I could get some help.
I want to start a new project that uses a touch screen numeric pad to enter a stored code (that can be changed by the user) to activate some electronics.
Would a picaxe be cable of doing this?
Is so, are there any recommendation on a suitable touch screen touch pad? Only need to be 4 digits to be fair, but I guess standard off the shelf would be a full 0-9 pad.
Many thanks in advance.
Russ
It actually depends on the hardware you are going to use for the touch input. Do you have a specific touch screen in mind that you will be using?
Hi Steliosm,
Thank you for your reply. I've not picked a touch screen yet, so I would definitely welcome some recommendations. It doesn't need to be fancy or anything like colour. Just a simple one colour LCD would do. Infact, even a back lit inductive keypad might be nice and simple and keeping with a flush design.
Many thanks
Russ
I used an old smartphone and a bluetooth receiver. Look at this thread especially post 8 & 10 by Inglewood Pete..
You could look at the nextion range of displays create your own lay outs and comunicate with serial to the pickaxe
Back
