TM1637 Demo for 6-digit 7-seg display
Buzby
I needed a 6-digit display for a project. There are some TM1637 examples in this forum, but they all seem to be for 4-digit displays.
The one I chose still uses the TM1637 chip, but this time with 6 digits. The display is available in all the usual places.
The one I got is labelled 'DM DIY MODE' as the manufacturer.
One quirk of this particular display is that the physical digit positions don't follow the logical order !.
The left three digits are swapped with the right three, and each group of three is numbered right to left.
This layout means the six digits are in the order '321654'
This might not be the same for a different manufacturer.
The code below was written for a 28X2, but it should be easily changed to work on most PICAXE chips that have enough pins.
' TM1637 6-digit 7-seg display
#no_data
#no_table
'Symbols
symbol clk = C.6        ' Clock pin
symbol dio = C.7        ' Data pin
symbol diopin = pinC.7     ' Data pin name
symbol BrightVal = b47
symbol ByteRAW   = b48
symbol ByteOut    = b49
symbol Digit1       = b50
symbol Digit2       = b51
symbol Digit3       = b52
symbol Digit4       = b53
symbol Digit5      = b54
symbol Digit6      = b55
' Code starts here
sertxd ( ppp_filename, cr, lf ) ' My identity.
' Allow time for TM1637 startup
pause 100
BrightVal = $80    ' Display off, prevents random stuff.
gosub SetBright
pause 2000
BrightVal = $88 : gosub SetBright    ' Set dim brightness
goto D1:
D1:
' Demo 123456
Digit1=1    ' Digit values, left to right
Digit2=2    ' 0 to 9 displays 0-9
Digit3=3
Digit4=4
Digit5=5
Digit6=6
gosub Display6dig    ' Call the display subroutine
pause 2000
D2:
' Demo ABCDEF
b50 = 10    ' Digit values, left to right
b51 = 11    ' 10 to 15 displays A-F
b52 = 12
b53 = 13
b54 = 14
b55 = 15
pause 2000
D3:
' Demo indirect, and dp
for bptr = 50 to 55
    b0 = bptr - 49 ' Make values 1-6
    if bit0 = 0 then : b0 = b0 + 128  : endif ' 2,4,6 with dp
    poke bptr, b0
next
pause 2000
D4:
' Demo brightness
for b5 = 0 to 3
    for b4 = $88 to $8F
        brightval = b4
        gosub SetBright
        pause 100
    next
    for b4 = $8F to $88 step -1
        brightval = b4
        gosub SetBright
        pause 100
    next b4
next b5
D5:
' Demo on/off
for b4 = 0 to 15
    BrightVal = $80 ' off
    gosub SetBright
    pause 100
    BrightVal = $88 'on, min brightness
    gosub SetBright
    pause 100
    BrightVal = $8F 'on, full brightness
    gosub SetBright
    pause 100
next
pause 2000
D6:
' Demo End
Digit1=17
Digit2=17
Digit3=14
Digit4=19
Digit5=13
Digit6=17
pause 2000
' Display off
BrightVal = $80
gosub SetBright
end
' Subroutines
'Translate to 7 seg
T7Seg:
    bit0 = 0
    if ByteRAW > 127 then    ' Detect dp
        ByteRAW = ByteRAW - 128
        bit0 = 1 ' Remember required dp
    select case ByteRAW  ' 0-15
        case 0 ByteOut = $3f  '0
        case 1 ByteOut = $06  '1
        case 2 ByteOut = $5b  '2
        case 3 ByteOut = $4f  '3
        case 4 ByteOut = $66  '4
        case 5 ByteOut = $6d  '5
        case 6 ByteOut = $7d  '6
        case 7 ByteOut = $07  '7
        case 8 ByteOut = $7f  '8
        case 9 ByteOut = $6f  '9
        case 10 ByteOut = $77 'A
        case 11 ByteOut = $7c 'B
        case 12 ByteOut = $39 'C
        case 13 ByteOut = $5e 'D
        case 14 ByteOut = $79 'E
        case 15 ByteOut = $71 'F
        case 16 ByteOut = $3E 'U
        case 17 ByteOut = $00 ' Blank
        case 18 ByteOut = $40 ' Dash
        case 19 ByteOut = $54 'n
    endselect
    ' Add dp
    if bit0 = 1 then : ByteOut = ByteOut + 128 : endif
'Send byte
SendByte:
    b0 = ByteOut : diopin = bit0 : pulsout clk, 1 ' seg a
    b0 = b0 / 2  : diopin = bit0 : pulsout clk, 1 ' seg b
    b0 = b0 / 2  : diopin = bit0 : pulsout clk, 1 ' seg c
    b0 = b0 / 2  : diopin = bit0 : pulsout clk, 1 ' seg d
    b0 = b0 / 2  : diopin = bit0 : pulsout clk, 1 ' seg e
    b0 = b0 / 2  : diopin = bit0 : pulsout clk, 1 ' seg f
    b0 = b0 / 2  : diopin = bit0 : pulsout clk, 1 ' seg g
    b0 = b0 / 2  : diopin = bit0 : pulsout clk, 1 ' dp
    pulsout clk, 1    ' End byte
'Drive the display
display6dig:
    'Send RAM start address
    gosub StartSeq
    ByteOut = $c0
    gosub SendByte
' NOTE : Physical digits are not in logical order !!!!
    '1st digit ( Left )
    ByteRAW = Digit3
    gosub T7Seg
    gosub SendByte
    '2nd digit
    ByteRAW = Digit2
    gosub T7Seg
    gosub SendByte
    '3rd digit
    ByteRAW = Digit1
    gosub T7Seg
    gosub SendByte
    '4th digit
    ByteRAW = Digit6
    gosub T7Seg
    gosub SendByte
    '5th digit
    ByteRAW = Digit5
    gosub T7Seg
    gosub SendByte
    '6th digit ( Right )
    ByteRAW = Digit4
    gosub T7Seg
    gosub SendByte
    gosub StopSeq
' Start comms sequence
StartSeq:
    high clk
    high dio
    low dio
    low clk
' Stop comms sequence
StopSeq:
    low clk
    low dio
    high clk
    high dio
'Set the brightness
'Bit 7 high, Bit 6,5,4 low, bit 3 = display on/off, bright = bits 2,1,0
SetBright:
    BrightVal = BrightVal AND $8F OR $80
    gosub StartSeq
    ByteOut = BrightVal
    gosub SendByte
    gosub StopSeq
Back
