premelec
OOps there is a bug in this code so 4th digit doesn't show - I think it's when I added first two digits blanking as it counted ok to 9999 b4-
I'll be back... ;-0 Yep its an error in READ before ENDIF position - I've corrected it here but can't delete attached BASIC file yet...
; TM1637 Demo & test code
; TM1637test5X.bas Not i2c - spi modified from various forum code;
; two lines required Clock & Data
; TM1637 4 June 2020 counts to 9999 OK... blank first 2 digits done
#picaxe 08M ;my test unit - should work ok on 08M2 206 of 256 BYTEs
;#no_data
setfreq m8 ; max frequency for 08M
;segment data for TM1637 Seg Bars clockwise from top - 7th bit on is middle bar
;Bit = 1 turns segment on
;( 0 1 2 3 4 5 6 7 8 9 A b C d E F dash blank)
DATA 0,($3f,$06,$5b,$4f,$66,$6d,$7d,$07,$7f,$6f,$77,$7c,$39,$5e,$79,$71, $40, $00)
;for TM1637
symbol datout = C.1 ; TM1637 data pin to 08m leg 6
symbol clk = C.0 ; TM1637 clock pin to 08m leg 5
symbol datain = w4 ; WORD byte to display 16 bits
symbol idx = W5 ; general index word var 16 bits
symbol bitdat = b0 ; holds bits to bang out
symbol D3 = b2
symbol D2 = b3 ;Extracted NUMERALS for 4 digits
symbol D1 = b4
symbol D0 = b5
gosub brightness ;set display brightness
DO ;increments digits by 1 to 9999 - could decrement with small changes for countdown
GOSUB GetDigits
GOSUB Display
pause 200
idx = idx + 1
Datain = idx
IF Datain > 9999 THEN ; reset to 0
idx = 0
pause 10000 ; long pause at 9999
ENDIF
LOOP
end ;JIC [Just In Case yoou get here...]
;Group of subroutines to read the values from data and output to the display
DISPLAY:
;Enable sequential movement (from one digit to next) NOT required??
#rem
Gosub begin7
b0 = $40 ;64
Gosub Out7
Gosub Stop7
#endrem
;Move to first digit
Gosub begin7
b0 = 192 ;$C0 ;192
Gosub Out7
;First value
B0=B1
IF D3 = 0 THEN
D3=17 ; blank
ENDIF
read D3,b0
Gosub Out7
;Second value
IF D3 = 17 AND D2 = 0 THEN
D2 = 17 ; blank
ENDIF
read D2,b0
;if b1 = 17 then
;b0 = b0 + 128 ;add 128 to turn on colon
;endif
Gosub Out7
;Third value
read D1,b0
Gosub Out7
;Fourth value
read D0,b0
Gosub Out7
begin7:
high clk
high datout
low datout
low clk
RETURN
Gosub Stop7
RETURN
Stop7:
low clk
low datout
high clk
high datout
RETURN
;Send a byte to TM1637
Out7: ; Bit bang SPI Out
pin1 = bit0:pulsout clk, 1
pin1 = bit1:pulsout clk, 1
pin1 = bit2:pulsout clk, 1
pin1 = bit3:pulsout clk, 1
pin1 = bit4:pulsout clk, 1
pin1 = bit5:pulsout clk, 1
pin1 = bit6:pulsout clk, 1
pin1 = bit7:pulsout clk, 1
pulsout clk, 1
RETURN
;Set the brightness ($88 = on, $88 to $8F 136 to 143 are the brightness levels)
brightness:
Gosub begin7
b0 = 136; 143 ;$89 ;137
Gosub Out7
Gosub Stop7
RETURN
;Subject: Extract single digits from WORD
GetDigits:
;datain = 0
D3 = datain /1000
datain = datain //1000
D2 = datain / 100
datain = datain // 100
D1 = datain / 10
D0 = datain // 10
RETURN
