PE V5.2.4
28X2 VB.0
I have this mimimalised program:-
Functionally, it works as desired except the interrupt is called noticeably less than once a second. Around ten times in 12 seconds.
If I remove the 'serout' line, the interrupt is called very close to every second.
The manual clearly states that servo, degug and timer cannot be used together but it does not mention serout.
Is serout expected to interfere with 'timer'?
28X2 VB.0
#PICAXE 28X2
#no_data
#no_table
#slot 0
hintsetup %01110111 ‘ enable all 3 pins (trigger when pushed)
setintflags not %00000000, %10001000 'interrupt if on buttons OR timer
settimer t1s_8
timer=65535
serout b.3,T2400,("data")
Interrupt:
pulsout B.4,100
flag3=0
flag7=0
timer=65535
setintflags not %00000000,%10001000
Return
