timeout doesn't work
hax
Hi all,
It's been a long time since I've posted on the forum!
I've just picked up a 08M2 for the specific feature of it having a serial timeout but it does not seem to be working for me.
Here is a simple program:
serin [1000,continue],3,N600,("ll"),b1
continue:
debug
The way I read the command in the manual is that in the above example, if no serial string is received, after 100ms the program will jump to the debug statement..... but it doesn't work, no debug occurs. Why?
It works for me, though a timeout of 1000 is one second. In what way does it not work for you ? And where is your input coming from; particularly is it a 433MHz module or similar ?
For detecting timeout events ( or lack of ) it's better to use SERTXD than DEBUG because it's much easier to see what is happening than rely on the debug received count in the title bar.
#Terminal 4800
sertxd(" Got data = ", #b1, CR, LF )
continue:
sertxd( "timedout", CR, LF )
As you are using pin 3 do you have the external diode to V+, you can sometimes get strange behaviour without it.
hax
It is a 433Mhz module..... Is that a problem?
I'm reading between the lines, and guessing that the command won't time out if there is spurious highs and lows on the serin pin?
Correct, you will be getting continuous rf noise spikes which keep resetting the timeout, so it never times out.
Use an NKM2401, or use a 14M2 and the rfin command!
hax
Ah, just looked at the RFIN command, and it also doesn't have a timeout.... so I'll have to use the NKM2401...
zebulon
You can also insert another 08M2 or 08M - or whatever you want - between your PICAXE and the RF input just to handle the communication. That's what I do and it work fine for me and this is a cheap and simple solution when the PICAXE you use isn't rfin compatible.
An example of code to put in the inserted PICAXE :
#picaxe 08M
symbol in_serie_HF = 1 ' Connection de la pin data du module HF sur le port 1 du 08M (pin 6)
symbol out_serie_filaire = 2 ' Connection du port 2 du 08M (pin 5)
debut:
	serin in_serie_HF, N2400_4, ("qualifier"), B0
	serout out_serie_filaire, N2400_4, ("qualifier", B0)
goto debut
Guillaume
