This one is bit from left field but theres such a high level of expertise here on the forum I thought it worth while asking. Somebody might be a welder or have experience with TIG welding on some level.
I have to fabricate some proto aluminium housings for a picaxe driven project.
I have a ESAB 180 amp MIG welder which I can use to weld aluminium if I make a few mods to it.
Is is it possible using the MIG I have to get a good result or am I better off to go and get a TIG to weld light sheet? (~3mm)
I have read that it is common practice to use a push/pull gun on a MIG when using ally wire, is this critical?
I have seen some cheaper TIG welders on ebay, are these worth considering or are they rubbish. I've seen guys on site using Fronius TIGs, I think they're the top end. Am I going to get significantly better result with a top end machine like that as opposed to a cheapo unit?
