thermocouples
Hubsy
I've read that,
'The picaxe is setup for Type K thermcouples'
but I can't find how.
I've searched all 3 manuals but can't locate the info.
using an 18M chip on pin 17, ADC 0
any pointers please ?
hubs
Where did you read that ?
Analogue input on a PICAXE is never setup for any particular configuration, it simply reads whatever it finds on its ADC pin.
From that thread and a quick forum search it appears you are likely to be needing a MAX6674 or MAX6675 to do the interfacing.
Search criteria of "MAX6674", "MAX6675" and "thermocouple" should bring up more useful information.
A thermocouple produces a very small voltage per degree at EVERY junction.
That INCLUDES the connections to its leads.
For this reason, a SPECIAL type of amplifier (thermocouple amplifier) is required. There are many different types, of which two are mentioned above.
They amplify the signal to a voltage large enough to be read by a PICAXE but just as importantly, they compensate for the voltages which are also generated at the connections. (cold junction compensation).
It is NOT possible to connect a thermocouple direct to a PICAXE and be able to read anything.
Hubsy
Anyone know a UK supplier for the MAX6675 chip please?
My usual suppliers have let me down this time.
