The idea isn't mine, I'm just passing it along.
I'm running my time-lapse cameras on AA rechargeables. Problem is that the pedigree/condition of the batteries is unknown.
Awhile back someone had the idea to power a quartz Analog Clock from batteries while loading the batteries with a known load. The length of time the clock runs while loaded gives a very good indication of battery condition. So I finally got around to putting it together with a pair of clock costing $3 each. I mounted the clocks to a piece of wood, added battery holders and a 5 ohm load resistor that I can switch in to load the batteries.
To connect to the clocks I cut a piece of wood the size of an AA cell and soldered wires to a few small pieces of tin. The wood holds the tin against the clock battery terminals - so I don't have to solder wires to it.
Works like a champ. I should have done this a long time ago. I was about to go out and get 3 rechargeable D batteries at $18 each to get enough capacity to run the camera for a week. No need. I found I had one battery that lasted 6.5 hours loaded (or about 85% of the rated capacity) and the other two were 3.5 and 2.5 hours respectively. So, basically, I was just running with only one good battery!
I embellished the original idea a bit with the load switch - then I can use the clocks as alarm clocks should the need every arise . . . and I added a terminal strip so I can connect the picaxe to power the clocks directly from outputs - saving time and effort when I need to measure long time delays - just set a spare output to work the clock while the 'axe is sleeping (using some diodes to reduce the voltage to the clocks).
