Test test test, test test, test test test. EDIT: Test, test, test.
Buzby Senior Member Apr 29, 2013 #1 Test test test, test test, test test test. EDIT: Test, test, test. Last edited: Apr 30, 2013
W westaust55 Moderator May 3, 2013 #2 I don't know about the "test" function, personnally I prefer the X1/X2 REV function and the end results of same. Code: SYMBOL stressed = 1 SYMBOL give_me = b0 IF give_me = stressed THEN give_me = stressed REV 8 ; reverse the stressed ENDIF Last edited: May 10, 2013
R russbow Senior Member May 8, 2013 #3 Westy, can I stress, read the manual! Fails the syntax check. Also REV revved is VER and you havn't defined what version to use.
W westaust55 Moderator May 10, 2013 #4 Fixed the syntax error since that is important to present good code for newcomers. but version is irrelevant (unless its gone slimy, furry or smelly) stressed REV 8 ==> desserts (yum yum - should reverse all stress )
