Test post project not debugged
bag57pipe
For fun, I decided to try to produce a simple stand alone control system using a couple of 08M2's, it is not really a practical system it was only intended to be a novelty circuit. The design philosophy was to keep it cheap, simple and easy to knock up on a breadboard, try it out and then scrap. Data is entered a nibble at a time, there are only 128 lines of code to play with, 16 instructions, six registers and no IDE! The only I/O support is limited to serial out, sound, ADC(raw or voltage), and port read/write. The main problem is first I am useless writing programs and secondly it is quite tricky debugging a program inside of a program.
18/12/20 added schematic for blink led need to update files
Back
