PE6.0.6.4
1) using the #terminal directive, and terminal initially closed, picaxe start before terminal = output lost
It works on second and consecutive downloads.
I guess a fix could be that PE launch the terminal first (so it is like during following downloads), then download.
2) After having downloaded a program which use "#terminal baud", and then edit that baud, and download again, the terminal is not updated with the new baudrate.
3) at http://www.picaxe.com/BASIC-Commands/Directives/hash-terminal/ it say max baud is 32400.
So it can not be used at 64MHz (!?)
I tried #terminal 76800 and i neither get syntax error nor anything in Serial Terminal. IMO, I should get either of it.
(used 28X2, 16MHz xtal, em64, sertxd)
4) at http://www.picaxe.com/BASIC-Commands/Serial-RS232-Interfacing/sertxd/
I suggest a cleanup for better clarity and less words:
Replace "(baud 4800, 8 data, no parity, 1 stop)"
With "Format is 8 data bits, no parity, 1 stop.
Remove:
"The baud rate is fixed at 4800,n,8,1 (9600,n,8,1 on X2 parts)"
Add:
"The baud rate depends on set frequency according to the following table.
Note that the default frequency is 8 MHz on X2 parts, 4 MHz on all other."
Remove:
"Effect of Increased Clock Speed
Increasing the clock speed increases the serial baud rate as shown below (non X2 parts)."
Remove:
Add:
Remove:
