Syntax errors
kmp24
The Microcontrollers program keeps telling me that i have a syntax error in my program, but the same commands have worked in other programs that i have written, why doesnt this one work.
Symbol delay = B0
delay = 100
high 0
pause delay
low 0
high 1
pause delay
low 1
high 2
pause delay
low 2
high 3
pause delay
low 3
goto main3:
main2:
high 3
pause delay
low 3
high 2
pause delay
low 2
high 1
pause delay
low 1
high 0
pause delay
low 0
goto main3
main3:
if pin4 = 0 then main4
if pin5 = 0 then main5
if pin6 = 0 then main6
if pin7 = 0 then main7
main4:
delay = delay + 5
pause 50
if delay > 250 then main8
goto main3
main5:
delay = delay - 5
pause 50
if delay < 20 then main9
goto main3
main6:
if pin6 = 0 then halt
goto main3
main8:
delay = 245
goto main3
main9:
delay = 25
goto main3
[code]
It should highlight the faulty line.
At a quick glance, I can see a jump to label "halt" but I can't find that label anywhere in your code.
After another quick scan, I can't see "main7" anywhere either.
kmp24
those were small errors, the syntax error which the program highlights was "unknown symbol pin4"
More than likely it's because you are using an 18X (or at least you've told the edititor that you are).
The 18X does not have a pin4!
Which PICAXE are you using?
Which version of the editor?
Mycroft2152
BB, our crystal balls must have been synched! Yup, i was awake very early this morning.
This is a good time to remind any posters to include as much info as possible, at least which PICAXE is being used.
The easiest way to do this is in add
#PICAXE 18X
as a line in the program.
This is just a directive to the interpreter.
Writng readable and understandable programs is another thread.
