Syntax error in PE6
rq3
This small chunk of code
   [COLOR=Blue]bintoascii [/COLOR][COLOR=Black]Kolls,[/COLOR][COLOR=Purple]b0[/COLOR][COLOR=Black],[/COLOR][COLOR=Purple]@bptrinc[/COLOR][COLOR=Black],[/COLOR][COLOR=Purple]@bptrinc[/COLOR][COLOR=Black],[/COLOR][COLOR=Purple]@bptrinc[/COLOR][COLOR=Black],[/COLOR][COLOR=Purple]@bptrinc                                   [/COLOR][COLOR=Green];massage for decimal point[/COLOR]
has been working fine, and passes syntax in PE5, and versions of PE6 earlier than the latest (which I just installed). In the latest PE 6.0.8.6 it fails syntax check. Note that this is one line out of 381, the code has been successfully stuffed into a 20M2, and the device worked as intended. My earlier version of PE 6 was 6.0.8.3, which accepted this line with no problems.
The error reads:
bintoascii Kolls,b0,@bptrinc,@bptrinc,@bptrinc,@bptrinc ;massage for decimal point
Syntax error on line 240 at/before position 56
Error: @bptrinc cannot be used as for variable!
Rip
My understanding is that there are issues with using @bptrinc in the BINTOASCII command so that use is no longer allowed; "@bptrinc cannot be used as for variable!".
If one wanted to force it, one can explicitly code for it inline or, perhaps most usefully, in a macro -
#Macro WordToAscii(wvar,n1,n2,n3,n4,n5)
  n1 = wvar / 10000       + "0"
  n2 = wvar / 1000  // 10 + "0"
  n3 = wvar / 100   // 10 + "0"
  n4 = wvar / 10    // 10 + "0"
  n5 = wvar         // 10 + "0"
#EndMacro
#Macro ByteToAscii(bvar,n1,n2,n3)
  n1 = bvar / 100   // 10 + "0"
  n2 = bvar / 10    // 10 + "0"
  n3 = bvar         // 10 + "0"
#EndMacro
WordToAscii(w0,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc)
ByteToAscii(b0,@bptrinc,@bptrinc,@bptrinc)
@bptrinc was never 'officially supported' within pseudo commands such as bintoascii, as it could lead to unexpected/incorrect results.
It is therefore correct that this earlier bug (allowing it to be used) has been removed in 6.0.8.4
AllyCat
Is there an "Official" list of Pseudo commands? I remember being quite surprised that SWAP came into that category (and had a "bug" with @bptrinc).
It is of course possible to "guess" most of them by the (large) number of bytes that each adds to the Program Code after a syntax check.
BESQUEUT
This is clearly documented in the online help and in the pdf.
But no warning about "pseudo commands" in the @ptr/@bptr description :
@ptr/@bptr is a variable name that can be used in any command (ie as where a ‘b1’ variable would be used).
AllyCat
But SWAP isn't (and neither is PWMDUTY, etc.). :rolleyes:
It would be nice to have a simple list without having to search through the online commands, or put every one individually into a syntax check.
It must be an issue in some conditions. I have used BinToASCII with @bptrinc in several programs without apparent problems.
Anyway, the macros that hippy recommends are almost as neat and take very little extra space.
The main specific issues are when @bptrinc is used as both target and result, or when dec and inc are mixed (yes people do do that sometimes!). We'll have a look at possibly relaxing the check to allow other scenarios where it would be ok.
rq3
Yes, that would be nice. While the example I provided was only for my own edification, I do actually use Picaxe chips in a commercial product. I would be less than pleased to see that code I had been shipping to customers is now "not allowed". Without knowing what is "not allowed", I have no way to have confidence in my own code. There needs to be a table, or chart, of potential issues with ALL of the Picaxe BASIC interpreter commands.
Rip
