I have a student running Win10. He has PE6 installed. He can successfully connect to a picaxe 08m2 via an axe027 cable. But he can't check the syntax or program the 08m2 as both the icons are grayed out. It doesn't work from the Picaxe menu list either. Restarting the program makes no difference. I suggested he remove and reinstall the program but he says he has a picaxe setup at home and it works fine there. I've asked him to bring his setup next week but, until then, has anyone seen this problem and is there a fix?
Thanks.
Thanks.
