Switch on/off a Wireless Socket via 433Mhz and USB-Interface
Manfred19
New member
Challenge: Wirelessly switch an electrical plugin socket via a USB interface.
Parts: old PICAXE-08M,
Cheap 433Mhz Modul,
Brennenstuhl Wireless Socket,
some Small parts.
Implementation: The code consists of a total of 24 bits + 1 sync bit at the end
A bit consists of an 0 and 1 sequence (Manchester)
0 bit 430 us on and 1150 us off (approx. 1/3)
1 bit 1150us on and 430 us off (approx. 3/1)
Examples:
 |  0  |  0  |  1  |  0  |sync
Switch coding Brennenstuhl Wireless Socket
has two DIP switches:
1122334455 AABBCCDDxxofon
where switch on corresponds to 00 respectively
and switch off corresponds to 01.
Example:
Switch       Buttons
      o        o
o o o   o    o   o o
1 2 3 4 5    A B C D
Examples:
11 22 33 44 55 AA BB CC DD xx of on
01 01 01 00 01 00 01 01 01 01 00 01 A On
01 01 01 00 01 00 01 01 01 01 01 00 A Off
01 01 01 00 01 01 00 01 01 01 00 01 B On
01 01 01 00 01 01 00 01 01 01 01 00 B Off
The PIC-AXE 08M sends the 20 * ON signal as soon as it receives power via the USB interface. This is sent via a Cheap 433Mhz Modul to the radio socket and it switches on.
As soon as the USB interface is deactivated (e.g. TV goes off), this is noticed via PIN 4 (IN3) over the loop. The PIC-AXE 08M is still powered by the 2200uF capacitor. This is enough to send the OFF signal several times until the capacitor is empty. The radio socket goes out.
I connected the data line of the USB interface to a USB socket, so that the USB interface remains fully usable.
To send the suitable signal I used PULSOUT. But I didn't find a suitable command to realize the pauses in between. The 08M does not know a PAUSEUS command yet. Therefore I took PULSOUT and put it on pin 5 (Out2), which I don't use.
;#picaxe 08m
;# Anschlüsse am PICAXE 08M:
;#                              +  2200uF
;#     USB Power +5V ----+->--+--||------------------------+--- 0V
;#                       |    |      +---U---+             |
;#                       |    +-- + o|1     8|o 0V---------+
;#                       |       0V o|2     7|o            |
;#                       |       0V o|3     6|o 1 RFCOUT   |
;#                       +->--+---3 o|4     5|o 2 Dummy    |
;#                            +------------------R47k------+
; Der Code besteht aus insgesamt 24 bits + 1 Sync-Bit am Ende
; Ein bit besteht aus einer an und aus Folge
; 0 bit 430 us an und 1150 us aus (ca. 1/3)
; 1 bit 1150us an und 430 us aus (ca. 3/1)
; Schaltercodierung brennenstuhl
; 1122334455AABBCCDDxxofon
; wobei Schalter auf on bzw. Taste jeweils 00 entspricht
; und Schalter auf off bzw. nicht gewählte Taste 01 entspricht
; Beispiele:
; 11 22 33 44 55 AA BB CC DD xx of on
; 00 01 00 01 01 00 01 01 01 01 00 01 A Ein
; 00 01 00 01 01 00 01 01 01 01 01 00 A Aus
; 00 01 00 01 01 01 00 01 01 01 00 01 B Ein
; 00 01 00 01 01 01 00 01 01 01 01 00 B Aus
; Hier:
;Example:
;Switch     Buttons
;    o        o
;o o   o o  o   o o
;1 2 3 4 5  A B C D
; 01 01 01 00 01 01 00 01 01 01 00 01 =  B On
; 01 01 01 00 01 01 00 01 01 01 00 00 =  B Off
symbol RFCOUT = 1
symbol RFD = 2
symbol H0 = 43
symbol L0 = 18
symbol H1 = 112
pause 300
; On
for b0 = 1 to 20
pulsout RFCOUT,H0        ;0
pulsout RFD,L0           ;
pulsout RFCOUT,H1        ;1
pulsout RFD,L0           ;
pulsout RFD,L0
pulsout RFD,L0
pulsout RFD,L0
pulsout RFD,L0
pulsout RFD,L0
pulsout RFD,L0
pulsout RFD,L0
pulsout RFD,L0
pulsout RFD,L0
pulsout RFD,L0
pulsout RFD,L0
pulsout RFD,L0
pulsout RFD,L0
pulsout RFCOUT,H0       ; sync Bit
pause 9
next b0
; Beim Strom weg wird der VCC Eingang noch durch einen Kondensator gepuffert
; An pin3 liegt aber die direkte Spannung an und geht vorher auf 0
; dann wird mit der Restkapazität des Kondensator das aus Signal gesendet.
SCHLEIFE:
if pin3 = 1 then SCHLEIFE
;Off
for b0 = 1 to 50
pulsout RFD,L0
pulsout RFD,L0
pulsout RFD,L0
pulsout RFD,L0
pulsout RFD,L0
pulsout RFD,L0
pulsout RFD,L0
pulsout RFD,L0
pulsout RFD,L0
pulsout RFD,L0
pulsout RFD,L0
pulsout RFD,L0
pulsout RFD,L0
pulsout RFD,L0
pulsout RFD,L0
pulsout RFCOUT,H0
pause 9
next b0
stop
